PCV fitting under TB size?
Old Jul 8, 2010 | 01:06 PM
ulakovic22's Avatar
I'm putting together a LT1 and having to get misc. parts to finish up. Does anyone know the size of the barb that needs to thread into the manifold under the TB for the PCV? I haven't had a chance to physically try different bolts and such yet and figured I would try my luck here.
Thanks,
Anthony
Old Jul 8, 2010 | 02:45 PM
I'm not quite sure, but don't force any bolts in there. You will damage the threads. It is a pipe thread (which a bolt is not).
Old Jul 8, 2010 | 02:48 PM
ulakovic22's Avatar
Thanks for that, I will definitely be careful then. I should be able to get a rough idea though on size cause it should still thread a couple threads before it starts binding up......at least that's the new plan now
Old Jul 8, 2010 | 03:38 PM
... but pipe fittings are not sized like bolts...
Old Jul 8, 2010 | 04:42 PM
ulakovic22's Avatar
I know taper and pitch are different, but shouldn't I be able to size it based on just physical shaft size? 1/4x16 bolt should translate to a 1/4x18 NPT or 3/8x16 to a 3/8x18?
Old Jul 8, 2010 | 04:51 PM
Kevin Blown 95 TA's Avatar
I'm pretty sure it's 1/4" NPT.
Don't put a bolt in there. You can get all the fittings you want in that size at any hardware store.
Old Jul 8, 2010 | 05:12 PM
brucer's Avatar
no where close with that assumption...
for example: a 1/4" pipe thread is actually stating the inside diameter of the pipe the fitting is used for.. a 1/4" pipe tap is way bigger than 1/4"
Old Jul 8, 2010 | 05:27 PM
ulakovic22's Avatar
Ahhhhh, ok. Thanks.
Old Jul 8, 2010 | 07:59 PM
MikeGyver's Avatar
It's just 1/4" NPT
HectorM52
Jul 30, 2017 11:46 AM
cristian1311
Mar 4, 2015 04:45 PM
bossco
Nov 29, 2014 10:18 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
