Patriot 8401-BSBC with SA rockers?
Old Aug 13, 2008 | 03:13 PM
krillformula's Avatar
Anyone running the patriot springs with Crane gold SA rockers?
Im trying to find a good spring to use with the crane gold SA rockers and I have read that the crane 10308 kit doesent fit well with the crane rockers due to the big retainer etc.
What spring choises do I have?
Old Aug 13, 2008 | 06:14 PM
NightTrain66's Avatar
nope, those wont fit with SA rockers.
The PACV 1218 bee hive springs will work and the Crane 99893 springs (same spring that comes in the 10308-1 kit) will work along with a different retainer/lock set up. If going this way, get some Comp 4770-16 locators also.
What lift or what cam are you looking for springs for?
Lloyd
Old Aug 14, 2008 | 04:50 AM
Thank Lloyd. The cam will either be my old LE1.2, cc503 or something like.
The pac1218 springs will work? I thought when using the +0.05 locks the retainer will sit too high and the tabs on the SA rocker wont have as much to align on? But I hope im wrong though
Old Aug 14, 2008 | 09:44 PM
the Comp 611-16 locks will work for that and clear the SA tabs.
Lloyd
Old Aug 15, 2008 | 05:05 AM
OK but that means shorter install height.. Hmmm
Old Aug 15, 2008 | 07:52 AM
You should be able to get 1.750" even with stock valves and this will allow a .600 lift cam.
What is the lift on the cam? If this is for an LE1 cam or CC 503, you will have no problem.
Lloyd
Old Aug 15, 2008 | 09:48 AM
Nice. Yes it will be the le1 or something in that range, no radical high lift.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
