passenger side long tube header list
Old Feb 3, 2004 | 12:41 AM
SiDeWaYZz28's Avatar
Question passenger side long tube header list
hey everybody i finally got the drivers side header in whhhooo hoooo!!!!!!nut now tommorow im starting the passenger side can you please give me a list of the stuff i need to take off to get that bad boy in???im going to write them down and check each one i do...thanks alot it will be a big help....and if u want u can throw in some ideas that will make it go smoother...and it goes through the top right???
__________________
Old Feb 3, 2004 | 12:47 AM
scoobysnax83's Avatar
Nothing much, just take the alternator off and you may want to remove the dipstick tube to save from breaking it. Thats just for starts. What kind of headers are they? Another way to make it easier is to unbolt the pass, motor mount and jack up on the engine while maneuvering it in. Good Luck....
Old Feb 3, 2004 | 12:51 AM
jet hot long tubes
Old Feb 3, 2004 | 12:52 AM
good choice, but I hate to say this, you're done with the easy part....
Old Feb 3, 2004 | 12:55 AM
i herd on 94s the passenger side is easier or did i hear wrong??
Old Feb 3, 2004 | 01:00 AM
I'm not really sure...
Old Feb 3, 2004 | 09:01 AM
IslandZ's Avatar
Mine went from the bottom, just remove the dipstick like mentioned, the starter (obviously) and mine went in through the bottom, it wasn't near as hard as the driver side. Though I had to jack the engine a little. I tried from the top (even removed the valve cover and comtemplated removing a rocker, but ended up doing it through the bottom. And don't mind all the people that claim they did a header install in 1 day, mine took 4 10 hour days to complete from start to finish.
Good luck and don't give up! It is sooo worth it when you are done.
Old Feb 3, 2004 | 10:29 AM
BriansZ's Avatar
I did mine from the top, but whatever way works for you. From the top I removed the valve cover, dipstick tube, and starter. Then I removed the motor mount and jacked up the passenger side and it slid in.
The header install was the easy part for me. Making my Hooker Y-pipe mate up with the Jet-Hot headers was more difficult.
Old Feb 3, 2004 | 10:40 AM
LWillmann's Avatar
Here's how I did the passenger side in my car: http://web.camaross.com/forums/showt...hreadid=212344
Old Feb 3, 2004 | 11:08 AM
ibanez6rg's Avatar
Pass. side was a pain in the *** for me. I just removed dipstick tube and starter. Jacked it up 32" or so.
Old Feb 3, 2004 | 12:47 PM
thanks alot guys...imma get started in an hour....thanks again ill let ya know when i get it in
transam_388
Mar 15, 2015 11:53 AM
Cam's maro
Jan 30, 2015 09:21 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
