passenger side cylinder head
Old Apr 19, 2004 | 02:48 PM
TenaciousZ's Avatar
Is all that is holding the accessory bracket to the head is two 15mm bolts? it seems that the bracket is just part of the head I don't see any seams between the head and the bracket. if I take out these two bolts will the bracket come off?
Old Apr 19, 2004 | 03:06 PM
ibanez6rg's Avatar
The bracket won't come off, but that's all that's connected to the head.
Old Apr 19, 2004 | 03:08 PM
TenaciousZ's Avatar
I mis-worded it. What I meant was If i take off the two bolts then the head will come off?
ZDriver96's Avatar
what ibanez said... the power steering pump tube wraps around the bracket so the bracket wont completely come out but will discount from the head so u can remove the head
Old Apr 19, 2004 | 03:10 PM
TenaciousZ's Avatar
thanks guys when I was looking at it, it looked as if the bracket was a part of the head and removing the bolts won't do a darn bit a good.
Old Apr 19, 2004 | 04:19 PM
Accy bracket 1
Accy bracket 2
Old Apr 19, 2004 | 06:17 PM
TenaciousZ's Avatar
Originally posted by shoebox
Accy bracket 1
Accy bracket 2
awesome, thanks
Old Sep 3, 2004 | 05:15 PM
blown383's Avatar
Re: passenger side cylinder head
Is it necessary to reinstall the 2 bolts for the accessory bracket that goes into the head? It was a pain in the *** to remove....
-B
alex5366
Feb 17, 2015 10:43 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Jul 4, 2005 05:00 PM
