pass. side header, what's that tube for??
Old Jul 10, 2003 | 06:13 PM
TMDZ28's Avatar
Question pass. side header, what's that tube for??
on pass. side header. there's one tube that connects to pass. side header. that tube is connected by one bolt. and that one bolt is a freaking pain in the *** to get it off and to install back. anyone knows how to put this bolt that connect that tube to the pass. side header?? that's where my header leak is at.....thanks guys
Old Jul 10, 2003 | 06:47 PM
TMDZ28's Avatar
ttt
Old Jul 10, 2003 | 07:03 PM
94formulabz's Avatar
I believe your talking about the EGR. Back of the engine right? What kind of headers do you have? Try some high temp copper rtv on it.
-brent
Old Jul 10, 2003 | 07:15 PM
TMDZ28's Avatar
i took off that bolt. i installed a edelbrock TES shorties headers. and i have not put that bolt back on. that's the cause of my headers leak now. i need to know how to put that bolt back on. thanks
Old Jul 10, 2003 | 09:14 PM
TW95Z's Avatar
I won't be smart and say "with a wrench!" What's the problem? Can't reach it? Bolt won't go in? Something missing?
Old Jul 11, 2003 | 11:03 AM
TMD95Z28's Avatar
the bolt wont go in... i think the header had a smaller/ tighter holes than the bolt..
should i get a new bolt or something??
btw TMDZ28 and my car have the same problem
Old Jul 11, 2003 | 12:14 PM
jdvm95Z28's Avatar
Well the first thing that i would do is clean that old bolt up with a wire brush and make sure that you can start a nut on it...... and then try and start the bolt into the header........I havn't delt with headers yet but if it was ment to go onto your model car then the hole should be the same size......another possibility is that you tried to force the bolt and buggered the threads......that would mean that you are going to have to run a tap down it to clean the threads back up.............hope it works for you.....mine was a pain too......
Old Jul 11, 2003 | 05:12 PM
TW95Z's Avatar
I agree with jdvm95Z28. Check the threads of the bolt and bolt hole. Could be dirt or extra coating material that needs to be cleaned out with a tap.
Old Jul 11, 2003 | 07:43 PM
Venom151's Avatar
I had a leak in the same place, just couldn't get the bolt tight enough to stop the leak. It didn't seem to want to seat properly, no matter how much I cleaned it up. It blew through the hi-temp RTV, so I tried a bunch of JB Weld around it, let it set 24 hours, and that sealed it up reeeeaaal goood. Just hope I never have to remove my headers for anything...........
Old Jul 11, 2003 | 09:38 PM
craigffb's Avatar
I had the same problem when I put my headers on. I had to get a thiner and longer bolt.
Old Jul 11, 2003 | 11:37 PM
LilJayV10's Avatar
When I put MAC headers on a 95Z I had to hook it back up, it is a PITA. I put some RTV on it and made sure that it seated in correctly, theres the tube in the middle and then theres a piece of metal that goes around it, and there's a hole in that which the bolt goes through. I pushed them together and started the bolt and wiggled it some while i was tighting the bolt down so it was centered correctly and it hasn't leaked......yet. Oh, and I did this with the Y pipe off. Good luck.
Man.....JB weld? That's a little harsh.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
