parts and price list from jegs on my rebuild
Old Feb 16, 2005 | 07:46 PM
oneslowz28's Avatar
well i have decided not to stroke it to a 383 im staying with a 350 .030 over. heres a new list of he parts i am ordering from jegs it includes prices and part numbers. please look over it and tell me what you think.
Blue Racer Aluminum Roller Rockers 270-WG3061 SB-Chevy 1.6 Ratio, 3/8'' Stud $232.99
Comp Cams Magnum Pushrods 249-7372-16 SB-Chevy, 5/16'', Standard Length $95.99
ARP Rocker Arm Studs 070-100-7101 (*) 3/8" SB-Chevy/SB-Ford $29.99
Crane Cams Pushrod Guideplates 270-13650-1 BB-Chevy, 5/16" $43.99
ARP Rocker Arm Adjusters 070-300-8243 3/8'' for .550 Wide Slot $49.99
Comp Cams Hi-Tech Double Valve Springs 249-986-16 set of 16 $84.99
Comp Cams Valve Spring Retainers 249-741-16 Super lock retainer Lock Angle: 10° $59.99
Comp Cams Valve Stem Locks 249-611-16 Valve Locks With Lash Cap Recess Lock 10° $24.99
Comp Cams Valve Lash Caps 249-621-16 Hardened Lash Cap Thickness: .080'' $34.99
Eagle ''SIR'' I-Beam Connecting rods 356-SIR5700BPLW $239.99
327-400ci Large 2.100''
Crank Journal (2.100'') - 5.700'' Pressed Piston Pin, 565-grams
SRP SB-Chevy Low Compression Forged Pistons 867-139628 4.030'' Bore $499.99
C/H, 5.7'' Rod, 3.750'' Stroke. 8/pkg.
Total Seal Gapless Piston Rings - TS1 Race Sets 901-T9090-30 Bore: 4.030'' $196.99
Top Ring: 5/64''
Second Ring: 5/64''
Third Ring: 3/16''
Clevite77 Race Proven Bearings 695-CB758P30 Rod set of 8 $5.99 each $47.92
Clevite77 Race Proven Bearings 695-MS909H10 Main Set - .010'' $51.99
Clevite77 Race Proven Bearings 695-SH1349S Cam Set (77-95 Only) $15.99
ARP Head Stud Kits 070-234-4401 SB-Chevy, OEM Cast Iron and Aluminum Chevrolet $139.99
ARP Rod Bolts - Pro Series 070-234-6403 SB-Chevy 305-307-350 $81.99
ARP Main Stud Kits 070-134-5401 2-Bolt Main without Windage Tray $39.99
SB-Chevy Large Journal Main Studs with Hex Nuts
ARP Oil Pan Stud Kits 070-234-1901 SB-Chevy, Hex $21.99
GM LT1/LT4 Timing Chain Set 809-12370835 1995-97 LT1/LT4 Extreme Duty Timing Set $245.99
total $2240.73
Old Feb 16, 2005 | 07:57 PM
hawk232's Avatar
Re: parts and price list from jegs on my rebuild
i dont know much about the engine clearances and stuff like that so im not going to mention anything about those, but a few things that i have noticed is that you are getting 3/8 rockers with 7/16 studs, in order to run a 7/16 stud, you have to run a 7/16 rocker, also im not positive about this but you have 5/16 pushrods down and 3/8 guideplates (that might be right but im not sure) and last but not least, you might want to consider a cloyes double roller timing chain (around 90) and a csi electric water pump (150) instead of the lt4 timing set, this set is stronger plus you have the potential to pick up a few hp from the water pump.
hope this helps, good luck with the project
Old Feb 16, 2005 | 08:08 PM
oneslowz28's Avatar
the sizes got mixed up but the prices are the same and i already have a csi waterpump in the mail to me picked it up for 60 bucks. do you know the part number on the clotes dbbl roller timing set? and a round about price of it
Old Feb 16, 2005 | 09:03 PM
oneslowz28's Avatar
does anybody have a part number and a price for the cc306 comp cam
Old Feb 17, 2005 | 12:47 PM
oneslowz28's Avatar
Ttt
Old Feb 18, 2005 | 10:26 AM
hawk232's Avatar
dont have any part numbers but the timing chain is around 80, the cc306, just look at the comp cams offered and find the one that has 306 in it and that will be it...
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
