Parts list for a NSA 1.6 install. (Besides the obvious)
Lets start with the important info...it has 88K on it.
I have the NSA rockers. I am going to get new valve springs (Combination Motors #612 springs), Hardened Pushrods, and guide plates. All will come from CM.
I was thinking that with the mileage I should get valve seals as well.
What else would you get?
I want to do it right so when its time for the cam I can basically feel confident that my setup will be stable. I don't mind spending money but I really don't need it to be prostreet quality.
Thanks for any advice/comments.
You will absolutely need the following:
1. an extendable magnet...get them at autozone for a buck
2. a good spring compressor...proform or moroso
ex: http://store.summitracing.com/partde...2370&view=2047
Do not under any circumstance buy a cheapo Autozone or Napa spring compressor...you will regret it!!!!!
I just did mine with about 80k. Valve seals were in good shape, I did not replace them.
Get a plastic hammer to tap the valve stems after installing the retainers to make sure they are properly seated. New valve cover gaskets might be a good idea too.
I got my spring compressor from NAPA, KD Tools # 3271. It is the same unit that Snap On sells. It has a removeable handle so you can put a wrench on it. That came in real handy, with a ratcheting box end.
I used an air grinder with a 3" cut off wheel to clearance the valve cover supports. Wash them out real well afterwards.
Thanks for the tip on the tool and the Valve covers.
I don't know if I need valve seals or not but I figured it cheap insurance since I'm already in there.
Is there any reason why I couldn't use the original seats and retainers?
Are "locks" also called Keepers.
I've always called them keepers (the part that goes between the valve stem and the retainer) but I wanted to make sure I'm thinking of the same part.
Thanks all
Thanks all
