Parts list for new cam, etc.
Old Apr 6, 2008 | 08:49 AM
  #16
9formula4's Avatar
The crane 10308s will sit on the stock seats in the heads, no need to add anything and you can achieve a 1.75" installed height.
Old Apr 6, 2008 | 11:00 AM
  #17
truedualws6's Avatar
As long as you are OK with 169# closed pressure installing these springs at 1.75"
is OK. Even after they lose some pressure you are going to be well over 140# closed.
These springs are intended for a 1.85" installed height. I would not install them
at 1.75" or use the stock spring seats. That's the beauty of this forum, you get to
take all this free advice and decide for yourself.
I chose to use Crane 96872 springs instead of the 99893 which are in the 10308 kit.
I did this because the 391#/inch spring rate for the 99893 is way more than I
need for my application. They both have the same closed pressure and are intended
for installations with longer valves, hence the 1.85" installed height.
Old Apr 6, 2008 | 12:17 PM
  #18
96' Formula WS6's Avatar
Just curious, why is installing a hi flo oil pump a bad idea. I thought they were supposed to be better.
Old Apr 6, 2008 | 12:19 PM
  #19
mdacton's Avatar
they suck they pan dry......
no need for it
Old Apr 6, 2008 | 12:20 PM
  #20
o ok. Thanks for clearing that up. Sorry for the bad advice.
Old Apr 6, 2008 | 12:47 PM
  #21
dangalla's Avatar
yeah just use a stock oil pump with the white spring in it from gm, and while your at it this is a good read
https://www.camaroz28.com/forums/sho...light=oil+pump
Old Apr 6, 2008 | 01:17 PM
  #22
rusnrno's Avatar
You're absolutely right. At times it gets a little confusing getting different viewpoints from different sources but if you break down and analyze the info you should be able to make to the right choices.
I see you live in Downey. It's very nice up there. Reno's not far away. Feel like taking a road trip to help me setup my valve train? LMAO
Old Apr 6, 2008 | 01:28 PM
  #23
96capricemgr's Avatar
I think some bad info that gets tossed around is pulled from Gen 1 information.
The LT1 oilpump is already a good improvement over older smallblock pumps in stock form, at least more like the after modification than the before shown in that article.
Old Apr 8, 2008 | 11:06 AM
  #24
Feel free to PM me with any questions. I've played around with a few different setups,
done a lot of research, made some bad choices, and hopefully some good ones as well.
Old Apr 10, 2008 | 06:42 PM
  #25
rusnrno's Avatar
Parts Day!
I went to Summit today and bought most of my parts. I'm very excited! I can't wait to get her back on the road again.
Here's some pics.
HectorM52
Jul 30, 2017 11:46 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
