Parts list
Old Feb 3, 2008 | 02:48 PM
tt1079's Avatar
Parts list
Below a list of parts I plan on replacing in my 95 Z which has 130k miles mostly original, new plugs at 90K, and K&N CAI. Water pump went out and leaked all over so here's the list of things I'm planning on replacing, any advise on any other parts I should consider?
Part # Item
ACF-1104032
DISTRIBUTOR,
ACF-12527741
Water Pump, Mechanical, High-Volume, Aluminum, Natural, Camaro/Firebird 1993-97, 5.7L
ARP-100-9904
Sealant, ARP Thread Sealer, 1.69 fluid oz.
CEI-108097
Optispark to Metripack Adapter, Replaces Original Harness, Chevy/Pontiac, Camaro/Covette/Firebird, LT1
GTR-4060642
Belt, Gatorback, Poly-V, Serpentine, 6-Rib, 64.25 in. Length
MSD-8226
Ignition Coil, Blaster Performance Replacement, E-Core, Square, Epoxy, Red, 48,000 V, GM
NAL-10128343
WATER PUMP TO BLOCK LT1/LT4
Old Feb 3, 2008 | 03:54 PM
Kaj's Avatar
Kaj
looks good to me. Just make sure you install everything how it was. It would be a shame to have to replace everything all over again.
Old Feb 3, 2008 | 08:40 PM
2000GTP's Avatar
Looks like a good list. Were the wires changed with the plugs at 90K?
Old Feb 3, 2008 | 08:59 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I would probably replace the timing cover seals for the optispark and water pump.
Old Feb 3, 2008 | 09:34 PM
tt1079's Avatar
No the wires were not changed, I should probably add those as well... I was plaining on doing the seal as well... I need to make sure thats on my order. Thanks
Old Feb 4, 2008 | 06:41 AM
maverickmk's Avatar
get a decent set of wires, don't go cheap
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
siguy
Nov 27, 2014 10:07 AM
The Seer
Nov 20, 2014 06:32 AM
SaxRulez
Jun 12, 2004 09:29 PM
