Pacesetter LT's + Y-pipe
Old Mar 14, 2004 | 10:51 AM
Cmr0z28's Avatar
I talked to redline performance engineering, and asked if I would need collector flanges welded onto the Pacesetter LT's if I bought them. He said:
"There is nothign to worry about with those. The y pipe is flaired
for a slip fit design. The y pipe fits over top of the collector.
SO if installed properly you will not have any leaks."
What do you guys think? Do you think it won't leak if I clamp it?
Old Mar 18, 2004 | 08:51 PM
95_LT1_6SPD's Avatar
you should be fine if you tighten it well enouhg
Old Mar 18, 2004 | 08:56 PM
ibanez6rg's Avatar
I would have it welded, not clamped.
Old Mar 18, 2004 | 10:29 PM
if your going to have it welded, you might as well just use flanges
Old Mar 18, 2004 | 10:40 PM
Brent94Z's Avatar
Super Moderator
I've got clamps on my 4" exhaust and no leaks. A properly done clamp isn't going to leak.
GREEN3112
Feb 10, 2019 09:19 PM
Quickss96
Jan 29, 2016 05:56 PM
football4life
Oct 4, 2015 07:48 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Slayer
Aug 17, 2015 03:55 PM
