pacesetter LTs install... driver side?
So, I have had shorties for 8 years now... was finally time to upgrade. I got the passenger side in with little work, but the driver site is much tougher it looks.
How far do I have to lift the motor? Do I HAVE to disconnect the steering shaft or can I raise it high enough to not? That bolt is so rusted shut it will probably never come off.
Lucky I didn't reconnect the motor mount bolt nuts, just put the bolts in.
Thanks in advance.
Thanks in advance.
I did one of those jobs once and didn't raise the engine, just took the steering linkage off. Maybe soak both bolts with some penetrating oil for a day or so. Worst thing that happened with our install was having one of the bolts not even be able to go through the hole in the header flange cause the primary tube was in the way. We found this out before trying to put the header in there, or we never would have got it in. We had to elongate the hole and installing that side was still a PITA.
I have pacesetter LT's on my '93 and I did it on the ground but I had the car high enough to move things around a bit. The stearing linkage did have to be disconnected but I didn't have a problem getting it loose. It was truly a PITA but its worth it.
Now on to all the annoying rattles and bangs that come with LTS. I didnt have any problems until I pulle the motor and put it all back in. Not the Heat sheild for the Cat Rattles at IDLE. And there is NO CAT, but the Header sits ups against the heat sheild, dont think you could even get a peice of paper in between them. LOL
I saw that on the passenger side. I have roughly the same clearance there and to the housing of the motor mount. I have no carpet, no exhaust past the headers, so it is going to be loud undoubtedly. I may put a true dual system on it eventually, but I cant wait for LOUD noises.
Going downstairs right now to pull off the steering linkage and hopefully drop this thing right in.
K, I got the bolt out, but now what? heh thought it would just pull right off. I hit it with a rubber mallet for a while with no luck. How do you pull that out of the slot? Just smack it for a while? I will do a search see what I see.
MAKING PROGRESS!!
Ok,
The header is SO CLOSE to being in place, I will keep searching for advice. What i am seeing though is that at the last primary on the driver side the lip of the header flange will not go past the lip on top of the head (where the valvecover goes). The last primary is hitting the part of the steering column that goes into the firewall. I think this may be the issue, and have seen people dremel or elongate the holes in the firewall that these sit through... Do I need to do this to get the clearance?
Anyone else run into this? Back to searching.
Ok,
