pacesetter long tube problems
Old Aug 22, 2008 | 12:03 PM
ascastil's Avatar
im having trouble putting the alternator bracket back on the bolt on the header. and also the angles on the bracket no longer match up to the alternator. it looks like a little bending would fix it but the biggest problem is getting the bracket back on first. any suggestions or input. thanks.
Old Aug 22, 2008 | 12:19 PM
MeanGreen97Z's Avatar
Where does the header interfere with the alternator? I've never heard of an issue even remotely similar.... pics? Do you mean the accessory bracket or the little v shaped part that goes on the back of the alternator?
Old Aug 22, 2008 | 12:55 PM
maverickmk's Avatar
are you talking about the #10 bracket in this picture? I left that off on mine
Old Aug 22, 2008 | 01:55 PM
ascastil's Avatar
Old Aug 22, 2008 | 02:12 PM
wrd1972's Avatar
Nobody re-uses that brace once they have started molesting their motor. You wont need it.
Old Aug 23, 2008 | 12:43 AM
ttop1986's Avatar
I tossed mine when I did my long tubes a few years ago.
Old Aug 23, 2008 | 01:55 AM
camarozz95's Avatar
I also got rid of mine you'll be fine its got enough brackets already.
Old Aug 23, 2008 | 12:28 PM
NightTrain66's Avatar
I ahve never seen that bracket used with headers. Consider it "weight reduction", lol. The alternator will be fine as long as the other bolts and brackets are tight.
Lloyd
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
StansZ28
Feb 19, 2015 07:39 AM
LT14LIFE
Feb 9, 2015 09:35 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
