pacesetter header leak.
Old Jan 11, 2007 | 02:09 PM
DontMixWithRice's Avatar
96 lt1.
mr. gaskets dont work. felpro's dont work. arp studs dont help. am i cursed? i sound like a coffee maker.
what should i try next? part #?
Old Jan 11, 2007 | 02:17 PM
blue 79 Z/28's Avatar
try those multi layer aluminum ones, they work like a hotdamn
Old Jan 11, 2007 | 02:18 PM
LT1 POWR's Avatar
Why don't they work? Are they not sealing up? Are the flanges on the headers completely flat or are they warped or something. I have heard Percys Aluminum gaskets work well.
I know when I first got my Pacesetter LT's the flanges were warped. But with enough heat cycles and retorquing of the bolts, it straightened itself out.
Old Jan 11, 2007 | 02:25 PM
well..ive had them in the car for sometime now, and no matter how much i tighten the bolts, the car sounds like its knocking really bad...especially under load...i dont know why its doing this.
the car is a lt1 swapped v6...and i dont know what to do. i changed out all the wires not too long ago because they were arching...so i dont know if in doing so it caused premature failure to a spark plug...adding to the problem...but all i know is that these gaskets arent workign too well.
about those aluminum ones...whats teh part number? who makes them?
Old Jan 11, 2007 | 02:32 PM
camarozz95's Avatar
The aluminum ones I used were made by percy's got them off summits site p/n was PHP-66031
Old Jan 11, 2007 | 02:33 PM
i use the flowtech ones on my drag car, work excellent, can take multiple swaps and they have never leaked.http://www.holley.com/99150AFLT.asp
Old Jan 11, 2007 | 05:00 PM
remaxracer45's Avatar
I used the percy's dead soft aluminum gaskets and have to say they sucked, had pacesetters on my 96 WS6. I will use something else when I put my motor back in. I will also have a machine shop go over my flanges. Tried different bolts as well which is also a pain in the aaaassss witgh these headers
just my 2 cents
Old Jan 11, 2007 | 07:42 PM
ttop1986's Avatar
I've had good luck with my Earl's header gaskets.
Koby
Jun 28, 2015 04:46 PM
BLK1997Z28
May 7, 2015 03:01 PM
drptop70ss
May 4, 2015 08:22 PM
WildRidez
Mar 27, 2015 08:22 AM
