P0151 sensor circuit low voltage. What does this mean?
Old Mar 7, 2004 | 09:27 PM
JTS95TA's Avatar
Last night my car started stumbling horribly and got worse SES came on then started flashing indicating I guess a misfire. Today I got the code it showed P0151 (Bank 2 sensor 1 sensor circuit low volts). Just a FYI I am on my second pair of new 02 sensors. Does anyone have any idea what triggers such a code and what could be causing it?
Thanks for any help.
Old Mar 7, 2004 | 10:45 PM
The PCM is sensing low voltage from your right bank pre-cat sensor. Maybe a connection or wiring problem since you said you just replaced it.
Old Mar 8, 2004 | 01:32 PM
nb 96 z's Avatar
Any luck on finding your problem? I have a similiar problem but havn't had the time to check under the car.
Old Mar 8, 2004 | 04:01 PM
JTS95TA's Avatar
nop I always seem to go back to my OBD1 PCM that stays in open loop. Runs perfect that way.
Old Mar 8, 2004 | 04:20 PM
nb 96 z's Avatar
Hmmm. Well i just bought a pair of new o2 sensors today so ill see what happens.
timmy39120
May 8, 2015 11:41 AM
4586
Mar 18, 2015 06:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Injuneer
Dec 15, 2014 09:36 AM
91Bird305
Aug 8, 2002 12:36 AM
