p/n for trans cooler line on 95Z
Old Apr 23, 2003 | 08:33 PM
Polo-94Z28's Avatar
Cool p/n for trans cooler line on 95Z
Just as it says. I am looking for the part number for a 95Z28 automatic transmission cooler line. Lower line coming out of the trans. Car doesnt have any special options. Thanks
Laterz
-Zach
Old Apr 23, 2003 | 09:31 PM
n2ceptor's Avatar
According to my parts CD it doesnt come pre-bent..It a 25 foot roll......
Tubing, service 5/16 coiled steel part # 12545100
Nut flare tube(for screwing into the trans) part # 15725180
clamp, size 6 Part # 15620999
Hope this helps....
Old Apr 23, 2003 | 10:15 PM
Polo-94Z28's Avatar
Much, thanks.
Old Apr 23, 2003 | 10:26 PM
If you have a hole or something in the metal pipe, just cut it and put a compression union on it.
Old Apr 23, 2003 | 11:07 PM
ZLT195's Avatar
I just went through this ordeal.
It is not pre-bent and its just a roll of 5/16 steel tubing. If you just want to replace the one line just get some 5/16 line from an auto parts store.
I think the longest you will find though is gonna be 5-6 feet long. The lines are longer than that but you can splice the two together with either a hose or as Shoebox suggested a compresion union. Or if you have a hole do as Shoebox suggested. Its way easier than lowering the tranny to get to those fittings on the tranny (if you have the tranny in the car).
Z~
Magenta_Hearts
Mar 29, 2017 08:54 PM
james007moore
Jan 1, 2016 01:14 PM
Airplanedoc
Parts Wanted
Apr 18, 2015 04:22 AM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
