P*%$#@!
P*%$#@!
Alright, i had some issue with arking as some of you may remember, i got it all fixed and found that i had a wire burnt in half, well i ran the new wires through what i assumed was the same spot and planned on getting some protectors for it before it burnt again... just so happens it already burnt up again in a week, can some one please tell me where I can run the drivers side back spark plug wire so that it doesn't burn up? It appeared to run through a space in between the block and the manifold but apparently that's not right
It runs through the factory shielding:
http://i2.photobucket.com/albums/y28...d/IMG_1020.jpg
If you no longer have this piece, you might have to get creative with some wire ties.
