oxygen sensors
Old Feb 17, 2005 | 06:44 PM
96KillaZ's Avatar
oxygen sensors
I have a 1996 dual cat camaro, I need to get new oxygen sonsors, I know I have four sensors but do I need to repalce the ones after the cat? I heard you only need to replace the front sensors and not the rears. Will changing the rears have any benifiet?
Old Feb 17, 2005 | 08:46 PM
OBE1 95Z28's Avatar
Re: oxygen sensors
The front 2 O2 sensors are used for closed loop control on the engine. The rear 2 sensors monitor your cats and throw a code when your cats go bad or the sensors go bad.
Old Feb 17, 2005 | 08:54 PM
96KillaZ's Avatar
Re: oxygen sensors
Just to be clear, all the rear o2 sensors do is tell me if my cats are bad, they serve no other pourpose? and should not be replaced if they are reading correctly, Is that right?....Thank You for your help
Old Feb 18, 2005 | 08:00 PM
96KillaZ's Avatar
Re: oxygen sensors
ttt
Old Feb 19, 2005 | 09:28 AM
OBE1 95Z28's Avatar
Re: oxygen sensors
No need to change your rear O2 sensors. Guys that delete their cats install rear "Sims", that simulate a proper signal of a rear O2 sensor.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
