oxygen sensor deletion
Old Apr 5, 2010 | 10:29 AM
StangCrusher350's Avatar
hi guys. i read it was possible to delete these o2 sensors.
1)is this info true?
2)if it is alright to delete these, do i just pull them and thats it, or should i run a block off on both headers where they screw in?
3)are there any drawbacks from removing these? ex. horsepower/torque loss (i highly doubt but you never know). Any problems that can hurt the engine mechanically? from my understanding they only read emission. so i guess question 3 is unnecessary but just in case
thank you
Old Apr 5, 2010 | 10:42 AM
bombebomb's Avatar
Well... if you pull them out, you should at least block off the holes.
I think if your going to remove them you should get it retuned, but I am not sure.
Not having O2's will force the car to always run in open loop, if tuned specifically for open loop I figure you could be ok.
That should give you a little info lol, I am sure one of the electronic gurus will help you better.
Old Apr 5, 2010 | 11:26 AM
RamAir95TA's Avatar
Short answers:
1.) Yes, it's possible to delete anything.
2.) Sure. Go ahead and pull them out and block them.
3.) Perhaps you should read up on O2 sensor function before experimenting with questions 1 and 2.
Even shorter answer - KEEP THEM.
Old Apr 5, 2010 | 11:41 AM
bw_hunter's Avatar
Well, you can delete them by simply unplugging them The car will NEVER run right that way as the computer needs to have their feedback to select the correct pulse width for the injectors, along with the fuel trims, etc. You will not acheive the full potential of the engine and you will drink fuel like crazy. Bottom line, don't bother doing this unless you take off the rest of the fuel injection and the OPTI ignition.
You can always run a carb and a distributor that way......
thats all i wanted to know. i just wana drive the car and im waiting for them to come in the mail. im getting antsy lol. the car was sitting since really early last summer. but thanks guys. ill keep 'em.
Old Apr 5, 2010 | 04:06 PM
monster81's Avatar
my Z didnt have O2 sensors from factory, but again it was speced for my region. we dont have emmision stuff round here hehe
Old Apr 5, 2010 | 04:29 PM
6SpdLT1Z's Avatar
I deleted the rears via PCM then left them in with my shorty setup. When I went to a ORY I didn't need to do anything. If you remove them block them off, but I wouldn't delete them unless you know it's best for your application.
Old Apr 5, 2010 | 04:47 PM
bw_hunter's Avatar
Not sure about this...if it has fuel injection it has O2 sensors. You might be thinking about the rear ones....
Old Apr 5, 2010 | 04:49 PM
bw_hunter's Avatar
He's talking about the front, primary, sensors as his is a '95 and doesn't have rears. Your statement, while correct, doesn't apply to his setup
Lt1son
May 27, 2015 10:35 AM
Z28sTunner
Aug 30, 2002 03:25 PM
ZZed
Jul 31, 2002 10:31 AM
busta9876
Jun 28, 2002 02:22 PM
84406
3rd Gen / L98 Engine Tech
Jun 19, 2002 07:57 AM
