overlapped cam bearings
Old Mar 13, 2005 | 01:36 PM
95z28txn's Avatar
hey guys,
I'm losing oil pressure to the top end after the car warms up i have a pretty moded top end. I plan on taking the motor out and rebuilding it because it is most likely overlapped cam bearing because pressure changes when i rev it up. i want to change the follwing when i have it out. Want to go 383 but i can't afford it so i plan on goign really strong in the bottom end and run some juice.
lifters
1.6 roller rockers
stronger rod's and crank pistons flat top? (suggestions?)
opti?
fuel injectors
350 turbo w/ 4000 stall
Should I get a high flow oil pump?
anything else i'm missing?
Old Mar 13, 2005 | 02:07 PM
Mindgame's Avatar
Re: overlapped cam bearings
Originally Posted by 95z28txn
hey guys,
You're saying you think you "overlapped" one of these ?
lifters
1.6 roller rockers
opti?
fuel injectors
1.6 rockers:
Either comp Pro Mag, Hi Tech or Harland Sharp aluminum.
rods:
Eagle or Scat H-beams or my personal preference is Scat I-beam with ARP 2000 bolts.
pistons:
On a budget nos motor I'd go to Diamond or SRP.
fuel injectors:
figure that out once you know how much nos you're running
oil pump:
Hi-vol isn't necessary. Std vol w/high pressure spring would be my choice
-Mindgame
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
