overheating problem....
Old Feb 11, 2006 | 08:58 PM
crAzy95z28's Avatar
well got the new engine back and its overheating..
thermostat was old so got a new one the 160 one. Well put it in still started overheating, well then i took it out and ran the car without a thermo. Seemed to work for about 5-10 min then started driving and overheated again..
Now im thinking its the waterpump. It does have about 110k+ miles on it. You think my pump just went out?
Randy
Old Feb 12, 2006 | 09:00 AM
crAzy95z28's Avatar
Re: overheating problem....
anyone?
Old Feb 12, 2006 | 09:04 AM
6SpdLT1Z's Avatar
Not sure, it could be the water pump. Might try the cheap fixes first, make sure theres no Air in your system (use bleeder screws under intake elbow) then replace the radiator cap. Are your fans coming on? Could be a clogged radiator as well.
Old Feb 12, 2006 | 09:17 AM
crAzy95z28's Avatar
new radiator and manual fan switch which are all all the time!
ive bleed the things several times.
and i usually bleed it on the srcrew on the side of the elbow, which is on top.
Old Feb 12, 2006 | 09:39 AM
Guest47904's Avatar
Guest
Could be the pump. But before you do that, have you taken the top cover off the radiator to look down in front of it see if there was any debris in there? Just a couple of screws to have a peek.
I say that cause I had one of those plastic grocery bags in mine and it blocked about 1/2 the radiator.
You can tell if the pump is working with the radiator full, start it up. When the thermostat opens, the level usually goes down a little and you see it flowing out the core and into the side tank viewed through the cap opening.
To properly fill it, I like to do mine (have to do it every year when my heater core gets clogged ) this way.
Fill the radiator and the overflow tank. Start the engine and keep adding until it stops going down. Then shut it down and let it cool over night. Check the level of both next morning and add as nec. Done.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
