overheating issue
Ok...this might be lengthy...my temp gauge pegged out at 260 today...nothing changed no smoke or perkalating....thats spelled wrong...i shut the car off let it cool turned it on and the temp didnt change...water pump thermostat radiator have all been changed. the gauge dropped back to normal and didnt change untill i got home and parked it...where it proceeded to flutter up and down. i havent had a chance to look at the wires and sensors...but im afraid to drive it to work in the morning....anyone got some ideas advice or just straight up answers? 95 LT1
Re: overheating issue
OK - a little confused - did you recently change thermostat/water pump/radiator and then overheating? Did the Gauge max out but the car never showed signs of overheating?
#1 - Check the level in the overflow & in the radiator - confirm it's not ACTUALLY losing coolant
The gauge is powered by a sensor in the front of the driver side head while the PCM from a sensor in the water Pump, and the dummy light actually has a 3rd sensor - which can simply be unplugged.
ShoeBox has a great page(s) on the cooling system:
ShoeBox Cooling - Operation & Testing
4th Gen LT1 F-body Tech Articles
I think this might be the link you were trying to post. Hope it helps !
