Overheating - Help Please Help
Old Aug 12, 2004 | 10:19 PM
RansZ28's Avatar
Question Overheating - Help Please Help
When I drive the temp is fine.
When I am at idle, the temp goes way up, as soon as I rev the engine to 2000+, its start to cool. As soon as I am back at idle, it starts to heat up.
What could this be?
How do I fix it?
Old Aug 12, 2004 | 10:38 PM
ZeeDub's Avatar
Re: Overheating - Help Please Help
i have a slightly larger issue..... my car overheats like a SOB no matter what i do.... i replaced the thermostat, and wired a switch to my fans to keep em on all the time while driving... and it STILL goes as much as 280 degrees.... now THATS a problem.... as for yours? im not so sure... you check ur thermostat? or do this, open your radiator cap and check how your cars water flow is.... sounds like it may be a water pump... when they start to go out they no longer have as much pressure to sustain a flow of coolant at an idle, so when u stomp on it, the motor increases the pressure of the pump, and cools it off.
Old Aug 13, 2004 | 09:51 AM
kroqz28gto's Avatar
Perform a pressure check on the cooling system. You may have a bad head gasket, or other leak in the system. Eliminate internal and external leaking as a problem.
What could this be?
How do I fix it?
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
