overheating
Old Apr 9, 2006 | 05:17 PM
96' TransAm LT1's Avatar
Question overheating
ok, my 96' T/A has been overheating for a while... i dont think it is the thermostat because ive had that problem before and it went from a fine temp to WAY high really quick, and took forever to come back down, but now it just goes up when im slowly cruising, and stop and go traffic (even when it's cold outside, just takes longer)... i figure its my fans, cause i got under the car when it was running and they didnt kick on... how do i fix that? and maybe thats not it, idk but im pretty sure, ne ideas would be great...tks
Old Apr 9, 2006 | 05:25 PM
JimboManJones's Avatar
Re: overheating
If you turn the a/c on do the fans turn on(they should)? Check your fuse panels also.
Old Apr 9, 2006 | 08:05 PM
tazz2u's Avatar
Re: overheating
Also have your PCM scanned for engine temp. control. It can be changed to come on at a lower temp like 180* or 160*. I belive the stock setting is 215*, Now this means the fans will stay on longer but you won't overheat either. Although you might have to bump the temp up in the winter months to get good heat for the interior.
Old Apr 9, 2006 | 08:38 PM
Re: overheating
good plan but... they arnt comin on at all...ever...lol
Old Apr 9, 2006 | 08:43 PM
Josh M.'s Avatar
Re: overheating
If you unplug you ECT sensor on the front of your water pump while the engine is running, first one fan should kick on, then the other.
If both fans stop working it is unlikely that both fans failed. It is unlikely that both relays failed. Check your fuses. - JM.
Old Apr 9, 2006 | 09:07 PM
Re: overheating
ok tks for the ECT idea... i checked the fuses..fine...and the relays i put the fog light relay in the fan spot and vise-versa and the fog lamps still worked but no go on the fans starting up...
Old Apr 12, 2006 | 10:25 PM
Re: overheating
well, took it in cause i had no idea... but i guess it was a air pump or something like that for the exhaust that had a short in it, and that was blowing a fuse that made the fans work...so, idk... got er' fixed though...
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
