overheating?
overheating?
My 94 z will run for about 5 minutes and the temp gauge jumps way up. I also notice if you turn the heat on the air is cool and normally will burn the hair off your legs. Coolant also seems to be leaking out of the water pump. I am assuming my water pump has failed but I am looking for second opinions
Brian
Brian
Re: overheating?
Yeah, it sounds like you need a new waterpump. How much coolant have you leaked, have you kept an eye on the level. If you are very low on coolant, as well as having a defective water pump, I think you answered your own question on why your car is overheating.
Re: overheating?
yeah the radiator was only half full i was pretty sure it was the water pump but just wanted to make sure. I am planning on an electric water pump and might as well change the thermostat at the same time
Brian
Brian
Noct
Jul 14, 2015 01:18 AM
warmeck
Apr 16, 2015 05:50 PM
