Overheating!!!!!!!!!!!!!!!!!!!!!
Old May 22, 2005 | 12:36 AM
JoshZ28's Avatar
I have a 1995 Z28 and recentely my A/C quit working allong with my radiator fans. This has caused me to overheat in traffic, have my fans just shorted out or is it something simple?
Old May 22, 2005 | 01:48 AM
MachinistOne's Avatar
Re: Overheating!!!!!!!!!!!!!!!!!!!!!
Check the fuses in the under-hood fuse box. Also check the fuse for the smog pump as it is also tied into the fan system.
Old May 22, 2005 | 02:26 AM
JoshZ28's Avatar
will do thnx
Old May 22, 2005 | 05:01 AM
phinger23's Avatar
jump the fans, pop out the relays, and i think its spots 1 and 5, and the fans will run constant when key is turn on to accy.
Old May 22, 2005 | 12:22 PM
JoshZ28's Avatar
all of my fuses are fine and still nothing. should I just get a relay switch?
Old May 23, 2005 | 09:36 PM
phinger23's Avatar
jump it like i said...
Old May 23, 2005 | 09:38 PM
Black1995Z's Avatar
this crap happened to me, check your fusible links by the battery....look for any corrosion or shorts... look as far as you can
http://shbox.com/1/fusible.jpg
credit goes to shoe box
Old May 25, 2005 | 08:09 PM
JoshZ28's Avatar
A friend of mine told me an interesting theory, he said that if my coolant was out that the compressor would not come on, and if the compressor would not come on then the A/C fan in front of the radiator would not come on. Could this be true?
Old May 25, 2005 | 08:41 PM
Slayer63b's Avatar
I have the same problem with my 93 Z as well. It runs almost to the red then the fan will kick on and cool it all down. and my a/c and heater will not work either. and somtimes the coolant light will come on. But it has from what I understand a brand new radiator and coolant, water pump/pancake optispark, and I just put in a 160 thermostat in it. I sure hope this is my problem too.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
