Overheating
Old May 31, 2003 | 07:45 PM
daveszcar's Avatar
Overheating
I just replaced my optispark and now that everything is back together it is overheating. Also the fans do not come on at all. Do I need to bleed the cooling system? If so how do I do it? Thanks
Old May 31, 2003 | 08:32 PM
red 95 z28 lt1's Avatar
you definatley need to bleed the coolant system if you havent with the engine running loosen the two brass screws by the waterpump (see pic) keep them loose untill coolant flows out then tighten. as far as the fans i would check all connections and relays im not too familiar with the fans. hears a pic of the two screws you must loosen one is on a big hose going directly to the waterpump and the other is on a smaller hose next to it
http://www.streetillusionsracing.com...emovehoses.jpg
Old May 31, 2003 | 08:35 PM
L44's Avatar
L44
check the fan relays in the fuse box next to the intake
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
