Over heating problems...
Old Nov 14, 2006 | 09:20 PM
  #16
86camarodude's Avatar
Unhappy Same thing
I've got a '86 that is doing the same thing. Flushed the system, made sure the radiator was clear of junk, replaced the reservoir, res cap and hose, added new radiator cap, new water pump, relays work, etc.
The fan is intermittent, but a mechanic friend swears just the fan wouldn't cause it to overheat. Runs fine on interstate, but when in stop and go traffic it blows and smokes.
Recommend replace the fan? What else? Thanks...
Old Nov 14, 2006 | 10:05 PM
  #17
HardcoreRM125's Avatar
They put fans on em for a reason. I would replace the fan if you know its bad. You replace the T-Stat ?
Old Nov 14, 2006 | 11:33 PM
  #18
and therm
yeah, covered that too...wasn't until recently found out fan was working intermittently, other times checking it was good to go.
Old Jan 12, 2007 | 06:48 PM
  #19
jwar19's Avatar
camarodude, did you ever fix this issue?
This is like my first post in years...I miss by baby
Old Jan 12, 2007 | 07:25 PM
  #20
micfly83's Avatar
Originally Posted by jwar19
[Edit]: Oh, and another thing I forgot to mention, the camaro is guaranteed to overheat when I turn on the A/C...ALWAYS...
Mine will get hot if the A/C isn't on
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
