over heating please help!!!!
Old Apr 22, 2005 | 12:45 PM
96 trans am's Avatar
Angry over heating please help!!!!
Hello everyone, I was driving to work today, and before I got a half mile down the road mile car was at 280, I stopped and turn the car off and check the hoses to see if one had a hole in it, none of the hoses had a hole in it and I heard a whinding soung from the front of the engine. I believe my water pump went out, but I'm try to make sure this sounds right. Can someone tell me where the cheapest place to get a water pump and what kind? If this doesn't sound right please correct me. Thanks everyone
Old Apr 22, 2005 | 12:55 PM
Z06Z28's Avatar
Re: over heating please help!!!!
I would prevent from driving it until you fix the problem. When the car has cooled, check the coolant level. If it's fine, maybe your thermostat is stuck and need a new one. If your worried about the noise and your water pump..after car has cooled down..idle the car and open the radiator cap to see if the fluid is circulating. Basically, your waterpump goes out when it starts leaking out the weap hole or starts pouring out like a faucet..like when mine went out..what a mess.
For future reference just in case...you can do a phone order to these two guys for cheap gm parts. Contact Info: Wholesale Gm Parts
Old Apr 22, 2005 | 02:23 PM
alright, tonight I'm going to take the t-stat out to make sure the thing is not stuck, if it still gets hot, what would you think it is?
Old Apr 22, 2005 | 04:44 PM
JohnD's Avatar
The thermostat is a real possibility although it wouldn't account for the noise. I had one quit in the middle of I35 and 5:00 in the afternoon and damn near burned the engine out. It got so hot that the gauges were flashing. Amazingly it didn't hurt anything. No prior warning at all. I intend to replce the thing with every coolant change from now on.
Old Apr 22, 2005 | 07:25 PM
well i got a water pump, what will i need to do before i pull the old one off, will i need to drain the coolant? or anything else?
Old Apr 22, 2005 | 09:38 PM
BLinindoll's Avatar
drain coolant, pull air intake hose, pull coil, pull fans, pull air pump, pull air pump bracket.... i think thats it.
Old Apr 23, 2005 | 10:01 PM
well i got my water pump off, and will be putting the new one on tomorrow, is there anything I need to do that people forget to do when they put there water pump back on.
Old Apr 24, 2005 | 08:59 AM
red 95 z28 lt1's Avatar
gaskets and clean the surface on the block. put teflon on the bolt threads. make sure u bleed the system.
Old Apr 24, 2005 | 09:54 AM
Dave89IROC's Avatar
don't forget to put the drive sleeve back in place
Old Apr 24, 2005 | 12:15 PM
alright put everything back on now, but i have 2 sensors that look like they are coming from the brake lines on the drivers front side of the engine compartment, can someone let me know where those sensor plug into, and also, I cant find where the air pump sensor is, I see that a sensor needs to be connected, but cant find where it comes from, can someone please help me on this. Thanks
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
