Over the heads.. elite spark plugs.com
Old Jul 11, 2005 | 07:47 PM
Heatmaker's Avatar
Advanced Member
Does anyone on here who has these spark plugs wires know the routing diagram? THese plug wires aren't numbered...and trying to scatch out trial and error time.
Old Jul 11, 2005 | 08:27 PM
matt65's Avatar
Re: Over the heads.. elite spark plugs.com
Good Question. I just ordered mine and will be monitoring this post.
Old Jul 11, 2005 | 08:43 PM
blind527's Avatar
Here
Just so you guys know, these plug wires are GREAT!!!!!!!!!! I assume you meant the wiring diagram for the opti spark.
If you're talking about the looms, it's easy as cake, and common sense when you are doing it. Good luck!
I took off the wires 2 days before I got these wires, took me about 20 minutes to take off both sides, the clamps were easy as cake. Putting these on took about 45 minutes, routing them etc., and them looming took the long time.
Old Jul 11, 2005 | 09:19 PM
Red5.7's Avatar
If you are talking about figuring out which they go to based on length ... I just held them all up and used the shortest ones for 1 and 2, the next longest for 3 and 4, and so on ... all reached just fine for me
And if you just needed the diagram for the numbers on the optispark and plugs... see the above post.
Old Jul 11, 2005 | 11:43 PM
Heatmaker's Avatar
Advanced Member
Thanks for the help... but I was kind of hoping someone knew wich wire was for which side. Some of the wires are within 1/2 and inch of each other and those are the wires I would like to know... so I can skip the trial and error thing.
Old Jul 11, 2005 | 11:44 PM
blind527's Avatar
You'll be fine....
My set had 3 sets the same length, there were only 2 that were barely uneven with each other, you'll be fine man.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
