Over 110mph horrible vibrations, but everything is fine at 80-90.
Old 11-20-2005, 01:42 PM
BlackLT1_TX's Avatar
What could cause such a high speed vibration when at any speed under 100 everything is fine. I mean, it is a real good vibration, enough that is slows me down because of it.
Any ideas?
-James
BlackLT1_TX is offline
Old 11-20-2005, 01:45 PM
Z28LT1_Just_Nasty's Avatar
Re: Over 110mph horrible vibrations, but everything is fine at 80-90.
Check your alignment, tire balance, air pressure. Could be a lot of different things. I wouldn't believe any of it would be serious.
Z28LT1_Just_Nasty is offline
Old 11-20-2005, 02:53 PM
vin1382's Avatar
Any ideas?
-James
I have something similar in my firehawk, and my 96 ta. in my 96, it around 100+, and my firehawk, 90-95+. Ive read that the stock lt1 driveshaft is usually the culprit, and a ls1 driveshaft swap is the cure.
vin1382 is offline
Old 11-20-2005, 03:21 PM
crAzy95z28's Avatar
i had a vibration like that before,..
ended up being my transmission (stall) was toast...
so if you have a stall or any work done to ur tranny. That could be it. also another thing to check into is your driveshaft!
crAzy95z28 is offline
Old 11-20-2005, 04:41 PM
slverbullet's Avatar
have you had the driveshaft off any time recently? try turning it 180* and see if this helps.
slverbullet is offline
Old 11-21-2005, 06:47 AM
curly's Avatar
Have you changed the tranny mount? If so, I hope you didn't use an ES mount, they have had issues since the mount seems to be out of spec with the factory mount. After my factory mount exploded, I changed to an ES mount which caused my teeth to chatter at higher speeds . If this is the problem, go with a factory LS1 style which has the "interlocking" design in case you break it (unlike the factory LT1 mount).
The LT1 driveshaft also has some balancing issues which could cause vibrations. I went to the 1LE shaft.
curly is offline
Old 11-21-2005, 07:40 AM
Cmr0z28's Avatar
If you're using a poly trans mount, swap it out for a rubber LS1 mount. This fixed my high-speed vibrations....the car was unbearable on the highway and got worse as RPMs/MPH increased.
Cmr0z28 is offline
Old 11-21-2005, 07:41 PM
1BadZ95's Avatar
I had that problem, it was my steel driveshaft. Bought a aluminum and its fixed.
1BadZ95 is offline
oldschool
02-09-2016 09:21 PM
andrewcapps82
06-02-2015 10:57 PM
04-16-2015 09:57 AM
grabbem88
02-10-2015 06:20 PM
karnykamaro
02-02-2015 01:37 PM
Quick Reply: Over 110mph horrible vibrations, but everything is fine at 80-90.
