ovcw
Old Mar 4, 2008 | 01:17 PM
northdakota93z28's Avatar
ovcw
how long will it take me to put them on?? they were on back order from thunderracing.com and i took a month!! so i want to put them on this week!
Old Mar 4, 2008 | 01:43 PM
shock6906's Avatar
It took me about 2.5 hours or so with my long tubes. I think. It was a while ago so my memory is a little shady.
Old Mar 4, 2008 | 01:44 PM
porksoda's Avatar
Yea your looking at 2 hours to do it right.
Old Mar 4, 2008 | 03:11 PM
good i am going to re gap my plugs and throw those on i hope that fixes my high rpm stumble!!!
Old Mar 4, 2008 | 08:11 PM
2000GTP's Avatar
Mine went on pretty quick as well. It was like a two hour job, I expected it to take longer.
Old Mar 4, 2008 | 08:13 PM
dangalla's Avatar
the hardest part is getting the dam boots over the wires, i almost threw them out during the procces a few times
Old Mar 4, 2008 | 08:33 PM
endobong's Avatar
Are these lengths correct? 1. 29" _ 2. 30.5" _ 3. 33" _ 4. 33" _ 5. 37" _ 6. 41" _ 7. 41" _ 8. 40.5" _ C. 10.25
Old Mar 6, 2008 | 12:55 PM
going to try them on fri, the pass side looks like hell drivers doesnt look so bad. wish me luck!!
Old Mar 6, 2008 | 01:20 PM
ssbowtie1's Avatar
I went between the water pump and the accessory bracket
I know the water pump gets pretty hot, but I believe the Taylor wires are rated to 600degrees.
Old Mar 6, 2008 | 01:30 PM
thanks i will giver a go!
Old Mar 6, 2008 | 01:32 PM
ssbowtie1's Avatar
A more detailed pic:
Anyone have pictures of routing behind the alternator/ps pump?
Old Mar 6, 2008 | 01:36 PM
i will take off some crap so i can get at it better!!
Old Mar 6, 2008 | 02:24 PM
Green96Z's Avatar
I routed mine under the alternator:
I was worried about the WP burning them, so I went that route. First I put the wires on the opti and ran them how they would sit, then marked them with a marker, took them off and cut/crimped them, then put them back on. Took about 3 hours (I didn't have a jack).
Old Mar 6, 2008 | 02:46 PM
thanks i have taken off the belt and idler and it is alot better i will do the under the alt too!! it looks like it is the best
Old Mar 6, 2008 | 06:13 PM
97 RedSS's Avatar
I went behind the alternator also then pushed them in the wire tray that is directly below the alternator. You can get them to fit in the stock tray, but it takes some effort..
Cody
