OVC People, is this correct?
Old Nov 19, 2003 | 09:27 PM
PoorMan's Avatar
Got my ovc talor kit from thunder. Take a look at this pic and tell me if this is the correct way to crimp the connectors on the wire. I do not know if this is the correct slot and the correct orentation of the connector using the crimping tool. Just don't want to screw them up right off the bat. It didn't come with directions.
http://community.webshots.com/photo/...00930846anSnot
Jeff D.
Old Nov 19, 2003 | 09:50 PM
Laymaster's Avatar
Hmm..that looks right, but that's not the way I did it. I just kept crimping around and around until it was tight.
Old Nov 19, 2003 | 10:18 PM
NOMAD's Avatar
Looks correct. Make sure to lube up the wire and put it through the boot first before crimping. That way you can just pull it back through. I worked and worked crimping mine, then pushig the boot over it until my brother came along and smacked me in the head
-Shannon
Nayr
Mar 3, 2023 08:34 PM
AviatorDave
Dec 19, 2016 06:35 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
WPHIG2
Aug 27, 2015 06:37 AM
