OVC Ignition wire question
I am planning to put a Over Valve Cover wire set on my 94 Z and was just wondering if they interfere with the oil spout, and/or PCV on the passengers side valve cover? From the picture at www.thunderracing.com it looks like it will interfere with the oil spout but not the PCV...also i could go with the side mount wires, but with my stock exhaust manifolds it seems like that will not work because the heat shields will block their fit. My car needs wires, and i would much rather them go over the valve cover, but i feel like i am SH*t out of luck either way i decide to go (Top or side) any input would help me out tremendously..thanks!
Yeah, The over the Valve cover kits or for the cars with headers. I dont think it would be possible to use that kit with manifolds. If you have manifolds, Try out MSD's 8.5mm wire set. Those seem to be a pretty popular choice around here.
But as far as the question goes, The OVC kit fits fine on both sides. Nothing is in the way, PCV, breather, or oil fill. It will work fine.
lbrowne
Nov 13, 2011 04:25 PM
Jul 4, 2005 05:00 PM
