View Poll Results: What Shock/Strut Set out of these two would YOU choose?
KYB AGX Adjustable
11
33.33%
Bilstein HEAVY DUTY
22
66.67%
Voters: 33. You may not vote on this poll
Out of these two sets of shocks, which set would YOU get?
Old Jan 5, 2004 | 08:43 PM
  #16
97firechicken's Avatar
i have been wondering this same thing for a while myself, but i hear more people say the KYB's.
Old Jan 6, 2004 | 09:15 PM
  #17
revtime's Avatar
The AGXs are good AFFORDABLE adjustable shock.
If I could afford QA1s then by all means I would have them, the Koni front drag shocks are awesome but I will never pay 350 each for a shock on a street strip car.
The KYBs are a nice step up from the stock decarbons anyone with a nerve in thier *** will tell you that.
Old Jan 6, 2004 | 09:23 PM
  #18
95 Z/28 LT1's Avatar
Super Moderator
Go with the Bilstiens. The KYB shocks adjustability feature is just a gimmick, really.
Old Jan 7, 2004 | 03:21 AM
  #19
chesee48's Avatar
c. qa1 hal's
but i like them both, however if you dont think you need to adj them often, get the bilsteins
Old Jan 7, 2004 | 07:56 AM
  #20
Tom R.'s Avatar
why are you posting this on the motor board. ask the question on the autox board.
The PO of my car put in what is basically a level two SLP suspension from different sources.
turns out the car handled terribly because the parts weren't matched. Doug Rippie uses softer springs and stiffer shocks in the rear compared to SLP. end result, the rear was too stiff, had terminal understeer until the progressive springs woke up, the snapped into oversteer mode. I was lucy to neutralize things by replacing the chrome SLP SS 17' wheels with stock 16x8s. as much as it decreases the look is as much as it increases the driveability of the car. yet nobody else had the same problem/solution as me.
So, before asking what shock is better, decide what springs are you using, what sways are you using, bushings, etc.
the problem with the camaro compared to my porsche is there are so many more choices for the camaro. that means so many more opportunities to mismatch things.
your goal should be balance, very good in all areas, not excellent in some, and terrible in others.
HarleyZ28
Oct 5, 2015 06:23 AM
FredM
Mar 6, 2015 03:04 PM
Jan 23, 2015 01:13 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
