OTVC Kit installation??
From looking at the pics in the instructions, it looks like it is telling you not to strip the wire down to the bare wire, is this true or am I just looking at this wrong?
It's been a long time since I put mine together, but I do remember the install. I slid the boot on the wire. Then removed all the insulation down to the wire (spiral core will look like a tiny spring). I folded the wire back. Then put the metal end on, and slid the boot back over the crimped end.
Crimping is really simple. I have a set of MSD crimpers so that really helped out a lot. Put the boot on FIRST, slide it back a few inches (use silicone spray liberally for this), then strip the coating, fold the wire back, put the opti end on, and crimp. Then slide the boot up and over the terminal (not too far) and then you're done. Really easy once you do a couple.
I would buy the aluminum crimp blocks that you place between a vice. They make a much nicer crimp. I bought one from a local speed shop several years ago for like $10-$20. I've used it many times... well worth the money.
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
