Ordered my SLP 160* Thermostat
Old May 26, 2004 | 07:24 PM
ReducedFat's Avatar
Talking Ordered my SLP 160* Thermostat
First "mod" on my car. I'm pretty stoked
Through word of mouth and just by observing I found out that a lot of people prefer this over a 180* stat so I went ahead and ordered a nice SLP piece. I really like the design of it because right now I'm running an AutoZone 180 which has a really small opening for the coolant to go through, smaller than the stock piece. The SLP part has a huge opening, much bigger than the autozone piece and certainly better than stock.
Now I was wondering if anyone could explain to me what the actual advantages of having a 160* stat are? Thanks a lot guys.
Old May 26, 2004 | 07:28 PM
Nestromo's Avatar
It runs cooler.
Old May 26, 2004 | 07:35 PM
96WhiteZ28's Avatar
The LT1s run really hot for better emmissions which makes power suffer. Run it cooler and you will see performance. Plus the coolant runs through the throttle body which heats up air coming into the motor unless you run the by-pass which is a mod which costs less then $10 and i don't know why i haven't gotten around to do it yet. Also with the motor running cooler you have less chance of detonation. The 160 degree thermostat is best used with a fan switch to make the fan turn on at a lower temperature also. Another way of doing that but it being more expensive is getting a hyper tech power programmer. I picked on up for $150 although i'm going to end up selling it once i get my PCM custom programmed after some big mods.
Old May 26, 2004 | 09:07 PM
ReducedFat's Avatar
Thanks for all the info, guys. After a search I'm definately happy that I bought what I did.
Old May 26, 2004 | 10:27 PM
MarkyMark's Avatar
Go
the 160 tstat wont really help you unless you have the fans turn on earlier or have a manual fan switch installed. What it does is open up at 160 degrees instead of the stock like 195 or something (not sure) allowing the coolant to circulate through the radiator, but the radiator doesn't do much if the fans arent on to cool the coolant. Although I guess regular air from the air deflector coming up will cool it a little. I just did mine yesterday though and the fan switch as well, but with my fans off the temps still get up there, but as soon as I turn my fans on the temps noticebly drop quickly. As far as first real mods I would get a cold air induction and then work on your exhaust.....onto tires, then maybe gears....and so on and so on.
________
sweetpussyXxxX cam
Old Jun 18, 2004 | 06:24 AM
CHRISCAMARO's Avatar
with the 180 thermostat which would replace the 195, do i need the hypertech to recognize the 180? just curious. thank you
Old Jun 18, 2004 | 06:43 AM
The stock thermostat is 180°. No programming is necessary for "recognizing" the thermostat.
from my Tech Page:
An often asked question is "Will my engine stay cooler with just a 160° thermostat?". The answer is yes, as long as there is good air flow across the radiator and the cooling system is working efficiently. Note that engine temps will still climb as they did before when you are stopped (as in traffic). However they may not rise as much, since you are starting out at a lower temperature than before. When you are moving again, it will be possible for the temps to lower more than what the 180° thermostat would previously allow. Cruising down the road, your engine should definitely stay cooler than before.
The thermostat only has control of opening temp to allow coolant flow, after that it does nothing but cause a predetermined amount of restriction in the flow. To make the most of the lower temperature thermostat, it should be accompanied by reprogramming of the fans, so that they will come on at a lower temperature. This will help to maintain a lower overall temperature in all driving conditions (especially when stopped in traffic). It is not mandatory that you do this and a 160º can be installed by itself with no other modification. You can see by the previous explanation though, how things can work together.
Old Jun 18, 2004 | 06:47 AM
i thougth stock was 195? good to know.
Old Jun 18, 2004 | 06:48 AM
teke184's Avatar
"the 160 tstat wont really help you unless you have the fans turn on earlier or have a manual fan switch installed"
this is not completly true
when sitting in traffic or in the staging lanes there will be little or no benefit from the lower stat.
HOWEVER...as soon as you start moving, and have airflow over the radiator, the benefits of the lower stat are iin full effect regardless of what temp the fans come on at! i hate guys saying that 160* stats are not effective without the fans programed...cause it's not true.
i drove with the stat for 2 yrs on my old lt1, used a fan switch about 10 times (traffic and 1 trip to the track). i was able to see the lower temps on the guage EVERY time i drove. and the fans were at stock settings.
Old Jun 18, 2004 | 12:14 PM
MarkyMark's Avatar
Originally posted by teke184
"[i]
I realized that after I posted......You are right if your are sitting still it doesnt do anything, but if your cruising or on the highway than you get the full benefit.....my mistake.
Old Jun 18, 2004 | 02:15 PM
BUBBA's Avatar
Still, in my humble opinion, if you're going with a cooler stat, you would be wise to program your fans.
Old Jun 18, 2004 | 10:07 PM
Nestromo's Avatar
No need to reprogram the fans if most of your runs are on the highway.
Old Jun 19, 2004 | 05:46 AM
jasons93z's Avatar
or just make a fan switch
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Biggiebound
Apr 21, 2015 11:28 PM
Jan 23, 2015 01:13 PM
