optispark vacuum leak
Old Aug 7, 2003 | 11:02 AM
ryaskovic's Avatar
There is a test spec'd in the GM manual for testing the optispark vent system for leaks. With the air inlet hose (the line that connects to the intake tract) plugged, 10" vacuum at the line to the intake manifold should hold (basically, the opti casing should hold a vacuum). The one installed in my car does not. The brand new one from GM I have at home does not either. It pulls air in from the electrical connector. If I plug that leak, it leaks from somewhere else.....the bearing in the back, I believe.
Has anyone done this test on their new optis? Do I have a "bad" new opti or is this a standard "feature"?
Thanks,
Rob
95Z28
Old Aug 7, 2003 | 10:20 PM
Mine is not all that old, but is not air tight either. I am having no problems, though.
KYWes
Jun 14, 2022 06:52 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
whitehooptie
Jul 12, 2015 06:10 PM
Nellsw88
May 26, 2015 05:55 AM
aklim
3rd Gen / L98 Engine Tech
Jun 22, 2002 07:38 AM
