optispark replacement
Hey guys, where can i find a step by step guide to replacing the optispark? Im getting a backfire out the intake at WOT and i think the opti might be the problem.
Re: optispark replacement
Unbolt the waterpump.
Use a puller for the crank balancer and hub.
Unbolt the opti.
I'd advise labeling the plug wires as you remove them as well. They're a PITA to trace. You may also need to pull the fan assembly off and the radiator. Good luck.
www.shbox.com also has some diagrams and schematics if you need.
Unbolt the opti.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
