optispark question
Old Jan 9, 2014 | 05:13 PM
kingkarny's Avatar
optispark question
Is it possible that a weak battery barely holding onto juice would effect the optispark
Old Jan 9, 2014 | 07:11 PM
Idontknow's Avatar
Re: optispark question
take the wire that runs from the PCM to the opti off and test the terminals you should have two 5 volts, a 10+ volt, and ground if your getting those readings your optispark has power.
Old Jan 9, 2014 | 07:17 PM
Kevin Blown 95 TA's Avatar
No, the battery just cranks the engine. Once the engine is running, the alternator makes all the power. If the battery is strong enough to start the engine, it won't be at fault for any problems while running.
Old Jan 11, 2014 | 06:23 PM
kingkarny's Avatar
I appreciate it well my issue is my battery in the cold Pocono mountains can't take it so when my car started spitting and sputtering I went right to that but even tonight.... I do pizza delivery....when I start it will take me about a mile down the road of spitting and carrying on before I get her to straighten out and act ok. I'll get back to the shop shut it down ten minutes later hop back in and get the same problems but I high rev and push her through it my next thought is fuel filter but if it is clogged it would do that more often then just at start up
Old Jan 13, 2014 | 06:47 PM
parkers Z28's Avatar
So your having a miss/sputtering only when the engine is cold ??
what year is your car ? any lights on in the dash ? can you scan for codes ?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
