Optispark Install question
Old Jul 18, 2007 | 08:04 PM
Dudeman41's Avatar
Ok this might be a stupid question but I want to ask anyway. I have a 94 LT1. Is it possible to put on the optispark 180 degrees off or will it go on only one way. I have it on now. I just hope I did it right.
Old Jul 18, 2007 | 08:15 PM
96z28t56's Avatar
i belive it will only go on one way, but your 94 could be different than my 96.
Old Jul 18, 2007 | 08:19 PM
Dudeman41's Avatar
Ya it could be. I dont know I have the small driveshaft that splines into the cam gear and into the optispark. I just wonder if it is possible to get that on 180 degrees off
Old Jul 18, 2007 | 08:33 PM
wrd1972's Avatar
Once you have the opti bolted on, start the engine without the water pump still removed. You can run the motor to ensure that the opti is on correctly, then install the pump.
Old Jul 18, 2007 | 08:42 PM
Dudeman41's Avatar
Well my engine is out of the car now. If I have to Ill just take the balancer off and the optispark to make sure.
Old Jul 18, 2007 | 09:45 PM
It can be installed incorrectly at any amount of degrees off-not just 180°. It is indexed to be properly installed only one way, though.
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
brentbrowning01
Dec 3, 2014 10:36 PM
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
