Optispark change
Old Nov 28, 2006 | 07:15 PM
davidarel's Avatar
Optispark change
So I was replacing my opti and then I decided to do some housekeeping. Enjoy!
Old Nov 28, 2006 | 09:41 PM
2000GTP's Avatar
So you were replacing your opti and decided to remove the entire front end in the process?
Old Nov 29, 2006 | 06:19 AM
davidarel's Avatar
Pretty much. I have always ben disgusted when I opened the hood. Everything was fading and getting scratched so I wanted to redo everything and start showing the car, finally! Basically doing everything I should have done many years ago when the LT1 went in.
Old Nov 29, 2006 | 07:49 AM
Sweetred95ta's Avatar
There's an easier way to change the opti.
Old Nov 29, 2006 | 09:03 AM
davidarel's Avatar
Well, it just snowballed. I saw alot of things that I didn't like so I "took care of them"
Old Nov 29, 2006 | 11:23 AM
ZFan88's Avatar
I wish I had more tools, lol, I would've done the same thing
Old Nov 30, 2006 | 10:44 AM
mzgp5x's Avatar
From the pics, you could run a rear "proven" distributor since your cowl does not cover the rear of the engine? This would get rid of the opti problem. Suggestion... I don't want to cause you any additional work.
Old Nov 30, 2006 | 11:55 AM
davidarel's Avatar
I dont mind using the opti where it is, plus, I already bought the new one.
Drtryder
Apr 22, 2015 04:17 PM
Dark Zeiro
Mar 11, 2015 07:15 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
