opti wire clip, crank sensor??
Old Feb 7, 2005 | 11:39 PM
Z28Horn's Avatar
any way, i had the wire behind the opti itself, three wire i believe, maybe 4 dont remember, but i accidently pulled one of the wires itself out of the connector, what i did was putt a little super glue on the tip of the wire and put back into the connector, Give me some advice on what i should do w/ this wire. Thanks.
Zach
Old Feb 8, 2005 | 04:09 AM
sssalah's Avatar
Re: opti wire clip, crank sensor??
If its one of the wires for the opti harness then a doubt your motor will fire, if its the cranck position sensor then you'll get an SES. Either way glueing isn't going to solve the problem. If it's the opti harness then you can change it, or repair it properly by soldring for example.
Old Feb 8, 2005 | 07:41 AM
Eff's Avatar
Eff
If it comes from above and is 4 wires its the opti, the crank sensor wire goes to the cranck sensor which is behind the crank pully, the optispark harness as its called runs 40-80$ depending on where ya get it.
HectorM52
Jul 30, 2017 11:46 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Lions3
Sep 2, 2002 02:08 AM
