Opti, where to get it?
Old Aug 23, 2005 | 05:03 PM
Tsar's Avatar
So as the title says i need a new one. I was wondering where i can get one the cheapest. If i buy the complete assembly it does include the coil pack too, right? or do i have to buy it separately? I'm gonna go check out delco website, but if someone knows anything else please post it. i need it ASAP.
Thank you for your help!
Old Aug 23, 2005 | 05:30 PM
Re: Opti, where to get it?
Parts contacts.
The opti does not include any coil. You should not need a coil, unless yours is broken.
Old Aug 23, 2005 | 06:50 PM
Tsar's Avatar
Aright thanks shoebox!
Ok another really newb question. Lets say i buy an opti, do i also have to buy a "cap and rotor kit" with it? Or does it come with the whole optispark assembly? If it doesnt, can i re-use the old one or you would recommend change it? if anyone could help, thanks!
Old Aug 23, 2005 | 06:55 PM
94Z28WP's Avatar
If you buy an opti from one of the people above it will be the complete unit.. If you buy one from Autozone etc. it will be just the optical portion and you'll have to buy the cap and rotor separate... That's the route I went, and if I had to do it over again, I'd buy the whole unit from one of the guys shoebox mentions on his site.
Old Aug 23, 2005 | 08:18 PM
The GM opti is complete (cap/rotor/housing) and ready to bolt on.
Old Aug 23, 2005 | 10:02 PM
95 TA's Avatar
How does the new MSD LT1 cap, rotor and housing compare? I've seen it in Summit for around $150. Is it superior to the GM Optispark for less $$?
Old Aug 23, 2005 | 10:17 PM
Victory Racing's Avatar
The MSD unit is really just a superior dust cover and rotor at this point. So if you were starting with a brand new unit it may be worth it, but if your opti needs replacing the MSD piece won't help.
I spoke with them last week and they intend to make a complete bolt on replacement for the Opti, but they were un-sure of a release date.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
