Opti Vacuum Line
Old Dec 8, 2005 | 08:32 PM
ChrisUlrich's Avatar
Opti Vacuum Line
If the vacuum line to the opti isn't plugged in, could that cause the opti to fail?
Old Dec 8, 2005 | 09:13 PM
OBE1 95Z28's Avatar
Re: Opti Vacuum Line
It would be the equivalent to the non-vented style optis that are prone to failing sooner than the vented style. The vacuum line sucks fresh air through the opti; source of the air is from your intake ducting (just before the TB).
Old Dec 9, 2005 | 10:26 AM
So then the answer is no, it wouldn't cause opti failure... thanks man.
Old Dec 9, 2005 | 02:32 PM
NVetro's Avatar
but it will cause a vacuum leak cus one end is connected on the bellows and intake manifold and the other side wasn't connected
Old Dec 9, 2005 | 03:21 PM
OBE1 95Z28's Avatar
Your opti WILL fail sooner because you're not venting it.
Old Dec 13, 2005 | 09:31 PM
Would cause the opti to perform poorly?
Old Dec 13, 2005 | 09:34 PM
ibanez6rg's Avatar
Is the line plugged at all? Could be getting dirt in the Opti.
Old Dec 14, 2005 | 11:03 AM
It wasn't plugged in at all... just a big vacuum leak.
HectorM52
Jul 30, 2017 11:46 AM
Patrick Kovack
Mar 8, 2015 09:26 AM
grgguy
17
Feb 23, 2015 07:57 PM
pologreen97z
Dec 2, 2014 10:42 AM
