Opti vacuum harness connected to all but elbow...problem?
Old Jul 4, 2006 | 03:11 PM
NVetro's Avatar
I am trying to figure out why my new 383 whats to die when i come to a stop light or red light, it idles perfectly but when i drove it and slow down it dips to 500ish rpms and stays there about to die, sometimes it will cut out or sometimes if it stays there long enough it will go back to idle. It was ruled out as being a tuning issue with various tests run, it appears toi be a physical issue. I was thinking this could be it...I converted my car to a ram air setup and vented opti, i have the vented upto connected via the vacuum harness to the intake manifold and to the opti, BUT i do not have the little plastic elbow that goes into the elbow or bellows (ram air guys) connected, i have it on the side of the motor. Is this causing a vacuum leak??? If so, can this be causing my issue?
Old Jul 4, 2006 | 04:04 PM
OBE1 95Z28's Avatar
Re: Opti vacuum harness connected to all but elbow...problem?
Yes without the other end of the vacuum line connected to the intake, between the MAF and the TB you've created a small vacuum leak. That's not helping your stalling issue but I don't think that's your only problem. Your IAC (idle air control) may be dirty.
Old Jul 4, 2006 | 04:13 PM
anaik's Avatar
If the restrictor is in the line between the opti and manifold there would be little of a vacuum leak, like was mentioned, but you are pulling dirty air into your opti.
Old Jul 4, 2006 | 04:31 PM
NVetro's Avatar
All my sensors are new, i guess i can put a hole into the bellow and then see where i stand with the dieing at the light issue...
Old Jul 4, 2006 | 11:04 PM
NVetro's Avatar
anyone?
Old Jul 4, 2006 | 11:26 PM
WeirdRich's Avatar
I had the exact same problem. Ended up being the maf. Also, is your tps reading right?
Old Jul 4, 2006 | 11:30 PM
NVetro's Avatar
its reading below .90 at closed, i think its like .80 or something, which is acceptable i think. It MITE be my maf, its the stock old one...HMMM intersting
Old Jul 4, 2006 | 11:40 PM
WeirdRich's Avatar
are you getting an ses light?
Old Jul 4, 2006 | 11:49 PM
NVetro's Avatar
No ses light at all, MITE be the maf, i had issues with it in the past as ive been using the z06 maf all these years....ummm, will unpluging it test to see if thats the issue or no?
detroit1994z28
Apr 19, 2015 08:11 PM
Injuneer
Dec 15, 2014 09:36 AM
Fedesna
Nov 23, 2014 11:06 AM
tbyrne
Aug 16, 2002 01:12 PM
