Opti vacum lines..what do they do???
Old Feb 5, 2004 | 01:12 AM
9T4LT1's Avatar
I recently was under my car cleaning it from a stubborn oil leak (one I still can't find) and I noticed that the previous owner had taken off the top opti line and plugged it with a bolt. I put it back where it belongs but was wondering why it would be removed in the first place. Is this some "speed secret" I was not aware of or was he trying to mask a bigger problem. The car runs the same with the tube on or off.
Thanks guys.
Old Feb 5, 2004 | 01:22 AM
Brandon 95 Z28's Avatar
Top opti line? Are you talking about a vented or non-vented opti? The vented opti has lines receiving air from the intake elbow, and a line going to the manifold.
Brandon
Old Feb 5, 2004 | 06:13 AM
Mtrhds94Z's Avatar
The vents [one in from the top of the intake elbow, one to the intake manifold thru a vacuum line[with a restrictor] ] remove moisture and ozone from the opti, by circulating metered intake air thru it, lessening corrosion, etc..
I'd hook that back up ASAP.. [no reason at all that it would be 'better' disconnected...]
Old Feb 5, 2004 | 07:56 AM
Re: Opti vacum lines..what do they do???
Thanks guys.
I assume by your name that you have a 1994, unless converted, you don't even have a vented opti. Both vacuum lines go into the bottom of a vented opti.
Old Feb 6, 2004 | 03:01 AM
9T4LT1's Avatar
Re: Re: Opti vacum lines..what do they do???
This is my first 4th gen and I'm learning more about the car everyday. I don't know if it's been converted or even what an original one looks like. I can tell however that mine has been changed at some point and time. I hooked the line back up and everything seems fine. Just weird that it was dissconected and plugged
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
