Opti Uh O..
Old Mar 12, 2004 | 04:24 PM
Sterlingsxe's Avatar
Opti Uh O..
Ok well i got the opti off and orderd the part from gm my firend works there. He got the cap. Its without the metal part. Is it what i need and can i just use the metal part from the other opti. Its just the cap that i got is that what i need or did i order the wrong thing. Please help
Old Mar 12, 2004 | 04:55 PM
ttt
Old Mar 12, 2004 | 05:01 PM
twdz28's Avatar
did you test to see if you where getting spark at the coil? most likely when an opti goes bad it is the optical eye that fails. If this is the case you got the wrong part. You should have bought the whole unit and just been done with it. But hopefully saving some money you got the right part. That never happens to me. I try and save money only to spend twice as much as I should have if I would just bought the right part in the first place.
Old Mar 12, 2004 | 05:02 PM
well i will just return it i dont care he works there
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
