opti questions... just replaced no start
Old Jul 13, 2012 | 08:55 PM
facstk17's Avatar
I have a 1996 Camaro SS and I just replaced the opti in it.. I just tried to fire it up and I could not get the car to fire. Sounds like it is pushing air out of the intake manifold? Is it possible that I just did something simple and don't need to tear it all apart? Maybe spark plug wires not on right?
Thanks,
Justin
Old Jul 13, 2012 | 10:02 PM
LT1553's Avatar
Re: opti questions... just replaced no start
What made you change the opti in the first place?
Old Jul 13, 2012 | 10:56 PM
Did you index the opti correctly during the install? Plug wires can also be put on in the wrong places.
Old Jul 14, 2012 | 12:39 PM
MgodzNightwoop's Avatar
Thanks,
Justin
i have a 1996 camaro z28. just replaced the opti on it. before u tear the car back down. check for vaccum leaks. and check ur firing order. if that isnt the cause. then u might have not got the dowel pin in the right place. i made that mistake too. had to tear it back down. made sure the opti was on right. and it fired right up. hope this helps.
Old Jul 14, 2012 | 02:23 PM
mrmint69's Avatar
Is your battery fully charged and everything completely hooked up correctly?
Old Jul 14, 2012 | 04:15 PM
96z28_lt1's Avatar
i had an opti internally inexed off also, my car strated though and wouldn't not rev up and ran reall reall rough
Sergio
Jan 27, 2016 04:27 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
pologreen97z
Dec 2, 2014 10:42 AM
