Opti Protection
Opti Protection
I was thinking about my vented opti the other day, and how to keep it operating.
We know that moisture is a damaging culprit. It is opined that the vented optis work better than the earlier models. However, the vent tube is connected to the intake boot, putting the opti under negative pressure.
When we design buildings here in South Florida (hot + muggy), it is a major no-no to allow the building to be negatively pressurized. If there's a leak, moisture intrudes.
I was thinking of disconnecting the opti from the intake boot and hooking it to the pressure side of the smog pump. That should put the opti under slightly positive pressure, so when water does splash on it, it isn't drawn through any leaks in the seal.
This would literally cost nothing to do. Anybody done this?
the reason for a neg press it there are bad gasses created from the hi eletrical transitions from the rotor to the cap...you need to get those gasses out.
Injuneer has spoke of it before, he can probly give you a more in depth explanation than me
Here is a little trick I found to find leaks in the opti that can let bad things in. Hook a vacuum pump to the opening that normaly has air drawn out by the engine. Place your finger on the air intake opening and pump it up.
If there are no leaks then the vacuum pump will quickly leak down and you can locate the leak with soapy water and address the problem.
I had a brand new opti that was leaking under the cap and around the sensor mouting screws. Those areas were sealed up and now no leaks using the vacuum pump.
If you dont have a vacuum pump you can suck on the hose too, just make sure you dont do this in from of your buddies.
So what kills the opti? Is it the O3 or is it water getting in?
I was under the impression it was the water. If you used pressure rather than vacuum to remove O3, then you can address both issues at once. That way when the opti does leak, it leaks air out rather than water in.
Formula Steve
Sep 19, 2023 08:31 AM
tdigger9899
Sep 7, 2015 10:56 AM
[Interior] Interior protection
themex2002
Sep 2, 2015 03:47 PM
