Opti O-Rings
Old Dec 21, 2006 | 09:02 PM
jjminch's Avatar
Opti O-Rings
The opti I picked up was missing one of the o-rings that go on the shaft. The only gasket set in town didn't include any replacements either. The closest sized one I could find is about 1-2 mm larger (or a c-hair for a more accurate term).
It's a really tight fit. Should I just force the opti in, or remove the larger O-ring and just run with one? The old opti didn't even have any o-rings on it. It won't take much force, with some oil to help. Not really sure what I should do here.
Old Dec 22, 2006 | 08:19 AM
RE AND CHERYL's Avatar
My wifes 96 has been missing one O ring for about 6 months. I assume they are there to keep the spline from moving around and causing wear to the shaft or the coupling.
Re'
Old Dec 22, 2006 | 09:07 AM
qboneus's Avatar
The felpro timing gasket set available at most auto parts stores has a set included.
Tal
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
